J Austin, Deere used the 180� crankshaft & therefore the 180� firing for a couple of reasons.. ~The first being ENGINE BALANCE.. It's just too hard to balance a 360� crankshaft when large parts are used.. The counter weights would have to be huge & the off order engine harmonics would be hard to deal with.. ~The second reason would have been low RPM torque,, the 180� crankshaft design is more suited to low RPM torque. ~I�m not sure starting was a big factor as most 180� & 360� engines fire each cylinder on every other stroke.. If the 360� did fire both cylinders at the same time then harder starting [well harder cranking anyhow] would be the result.. ~Most big cylinder engines use the 180� firing & a lot of smaller high revving motorcycle type engines use 360� crankshaft designs. Harley Davidson uses a unique 315�/405� design as the crankshaft only uses one crank rod pin for 2 cylinders.. ~The 2- cylinder R pony uses a 180� crankshaft design but that engine is an opposed twin engine so it is different than an engine with both pistons on one side. ~The older Deere 2 cylinder [farm tractor] diesels are also 180� design. ~Both designs have their place & the 180� just worked out better for Deere in their large piston low RPM farm tractors.. ~The intake breathing was a problem with the early single carb systems & the R/H cylinders didn�t their share of fuel/air at low RPM�s but Deere rectified that problem on the later designs when they went to the duplex carburetors with a separate carb venturi & throttle plate for each cylinder.. ~The 180� firing on the old 2-cylinder Deere is what gives it that unique popping sound at low loads & that double pa-putt at working loads. [email protected]
