Tim, if you wish to convert your tractor to a 12 volt battery and charging system, you can do that and STILL USE a 6 volt starter. You CAN NOT (within reason and cost and pure physical size etc for sure) buy some sort of "Voltage Regulator" as you asked to reduce the battery voltage down to 6 volts to run that high energy starter. (Just buy a 12 volt starter if you needed one, its available, cheap, practical and easy) True, you can buy all sorts of solid state voltage regulators or even use pure resistive ballast to reduce 12 volts to 6 for powerign low power devices, JUST NOT THAT HEAVY CURRENT LOAD HIGH WATTAGE STARTER MOTOR. Just apply 12 volts to it and it will run, just avoid extended periods of cranking so she dont overheat. If you insist on changing the entire tractor to 12 volts, you would need a 12 volt battery,,,,,a 12 volt Generator and Voltage Regulator or cut out relay system,,,,, ,,,change lights to 12 volt bulbs,,,,, ,,,add a voltage dropping ballast resistor ahead of and in series with your ignition coil if its a battery powered coil ignition system and you wanna use the existign 6 volt coil (no change needed if its a magneto). I reccomend you consider just repairing any 6 volt problems includign the starter, then use 00 Gauge Battery and Starter and Ground cables, then use the heaviest duty highest amp/hr or CCA rated battery you can fit in the compartment, and have the charging system in top shape to keep the battery charged. Gauges can be found at Antique Guages Inc., and Starters from various suppliers seen/linked here or in Green or Two Cylinder magazines or over on www.johnnypopper.com. Good Luck n God Bless Post back or e mail [email protected] for more directions if you wanna change to 12 volts, but why not keep her 6 as original??? John T
