JD35D, the carb adjustment shouldn't be a problem for starting but can make a little difference.. ~Those old D's like: around 1 to 1-1/2 open from seated on the load screw & around 2-1/2 open from seated on the idle needle for initial starting.. ~You might try removing the entire air cleaner then trying to start it.. If that air cleaner inside wire mesh is plugged with gunk, water or old oil it could be restricting the air flow enough to hinder starting & cause your flooding... ~If removing the air cleaner doesn't help you probably should check the cam timing to see if the exhaust valve is opening at the correct time.. ~What magneto are you running? If the original gear reduction mag you need to be sure it is timed to the L/H compression TDC & not the L/H exhaust stroke TDC.. ~Another thing to check is that the spark is strong enough to spark under compression..To do that take an old [known good] spark plug & open the plug gap to 3/16" [use a 3/16 drill bit as a gap gage] then install that in each plug wire & see if you are getting a bluish spark to jump that 3/16" gap.. If not you still have ignition problems.. ~If the spark is weak make sure you are using solid metal core plug wires & NOT automotive TVRS carbon core resistor wires [they just won't work good on a mag system] ... ~Make sure the mag is snapping with a good loud snap [at least the Wicos will snap with a loud snap].. If the spark is weak try adding a second gasket between the mag & governor.. ~With all that flooding you really should install new spark plugs [again]..Once those plug center porcelains fuel foul they tend to not spark good under compression... ~Make sure the water valve isn't open or leaking as that can allow water to be drawn in during the intake stroke when the is choke on. ~Try starting that D with very little to no throttle opening & as soon as raw fuel comes out the petcocks open the choke for a few revolutions then go back to 1/2 choke.. ~Your D shouldn't start that hard.. If it is getting plenty of air, fuel, compression, & spark, it should start... You might try pull starting it the first time... Maybe once running it will start easier the next time..... . [email protected]
