Diffrential grease in JD A Still Has water!
GB
04-03-2004 18:23:15
I changed the rear end grease in my A and it was very milky looking. I put some Kerosene in it and drove it around a bit and drained that out and filled her up with 90 wt GL-1 grease. Drove it around and checked it and it is still milky looking. Would it be worth my time to drain it again and start over or just leave it alone and run it the way she is?
GB
John
04-04-2004 07:56:17
 Re: Diffrential grease in JD A Still Has water! in reply to GB, 04-03-2004 18:23:15
I am not sure on an A but it may have more than one drain plug, one will be under the transmission and another plug under the axle housing that will be flush with the housing that will require a 3/4" ratchet and extension to remove you may also need to swing the drawbar to one side to see it
Clooney
04-04-2004 07:48:18
GB, those old 2-cylinder tractors have all kinds of places that water can hide in, like the quill bearings, & side cover area.. Even if you change it again you will probably have a little moisture still in it.. You have a few choices,, one is to drive the tractor for a while, then change the trans oil again. OR, put that tractor to work for a few hours in hot weather,, OR, drilling the drain plug(s) for a 1/4" bolt then installing a 1/4" bolt with a slot cut in the bolt about 1/2 way down.. After the tractor is parked for a while just open the 1/4 bolt a little & let it drip until any water has dripped out.. If you do that enough times it should remove most of the water that settles out of the gear oil..
[email protected]
GB
04-04-2004 18:50:09
 Re: Re: Diffrential grease in JD A Still Has water in reply to Clooney , 04-04-2004 07:48:18
Thanks for the tips Clooney. I think I will wait and work her good this summer one 95 degree day that we have here in SC and drain the fluid out and start over.
