JD 1020 3PT Control Lever
Shorty
04-03-2004 16:24:44
The 3 PT control lever on my 1966 1020 has broken off where it is welded to the stub that bolts to the handle. I bought a new lever and am wondering what I have to do to remove the broken one and install the new one. thanks for the advice.
premier_industries
04-13-2004 19:19:03
 Re: JD 1020 3PT Control Lever in reply to Shorty, 04-03-2004 16:24:44
Well, I thought those kind of things only happen to me.
I had the same situation happen to me about 2 years ago.
It took me a good 5 hours with help to replace it.
Although I remade my lever in that time also.
( made the pin 1/2" longer and really welded it )
If I remember correctly that lever is pinned to something inside of the tractor with a roll pin.
That being the case you need to take off the seat, the 3 point arms, and the rockshaft cover to get at it.
My advice to you would be take your time, work on it in a clean garage, get a good helper, and grease up the new one real good before you put it in. ( so it doesn't rust up inside of the quadrant assembly again ) ( thats probably why it broke ).
Don't worry I'm sure I'm making it sound a lot worse than it is.
P.S. It wouldn't hurt to have a technical manual on hand.
Regards
premier_industries
