CJ, I agree with the good info below of Kerry n Clooney, heres my take on your questions: How did they work: Same as gasoline in an internal combustion spark ignited engine, it was that the distillates (drip fuels, somewhat similar to todays kerosene) were vey cheap so the tractors were designed to run on them. The main differences necessary to make that fuel work were: 1) The compression had to be lower to prevent pre ignition spark knock as they were lower octane. 2) The manifolds had to be hotter in the intake area portion (HOT manifolds) to keep that heavy fuel in a vapor state. 3) They had to be started and ran on gasoline until the engine and manifold temperatures were sufficient to burn the heavy fuel and keep it in a vsapor state prior to combustion. 4) The All Fuel Carbs were slightly different than the gas only. They were started on gas contained in the small rear tank, and once warmed up to 180 to 190 range, the brass 3 way valve (Fuel Gas Off) was switched over to the big main fuel tank. They were again switched to gas for cool and shut down so gas, not fuel, remained in the carbs. AS MUCH POWER?? Im no fuel man or chemist, but understand lower HP was due to the fact they had to run at much lower compression (prevent pre ignition) but that theres actually more BTU energy per volume in the heavier fuels. Great topic for discussion, thanks CJ, Good Luck n God Bless John T
