JD 50 smoking black
Tom
04-03-2004 14:34:17
my 50 smokes black a lot when running. It starts good but is over fueling some how. i tried adjusting the main screw on the bottom of the bowl but still smokes alot. Any help from anyone? Thanks
John Van Valkenburgh
04-05-2004 16:19:22
 Re: JD 50 smoking black in reply to Tom, 04-03-2004 14:34:17
Chris,
It might be a float problem (like its adjusted too high or sticking or float full of fuel and sinking). Another thing to check is that the choke butterfly is actually releasing properly. Its spring loaded and can stick closed.
If the problem is neither of those then I'd suspect a clogged air passage in the carb.
Best of luck,
John (1953 model 50)
halfmoon
09-17-2004 09:30:12
 Re: Re: JD 50 smoking black in reply to John Van Valkenburgh, 04-05-2004 16:19:22
My choke lever is a cast piece, says "Marvel - Schelber" on the "bowl" that covers the choke plate shaft. I see a pin or pins through the axis of the shaft. The top pin, moved by the choke lever, was a little bent. A spring was in there, with one end curved to hang on one pin or the other, and the other end straight -- I do not know how the spring is supposed to be, but it looks like it should keep the top pin nested in its notch on the choke lever. Also, a small hole on the carb casting at about wide open for the choke plate - is there another pin missing from that hole, or part of my spring, or nothing? Can you direct me to a diagram for the carb, and/or describe the spring attachment? With appreciation, Steve
Chris
04-03-2004 16:55:16
Did it just recently start or has it been doing it for a while? Does the tractor start ok and handle a load OK?
