4320 Wide Front End
Wes
04-03-2004 11:21:16
I have a 4320 with a John Deere 158 Loader. Is it possible to put a 4520 or 4620 wide front end under a 4320? I'd like to have more of a heavy-duty front end on my loader tractor. Thanks for any help.
mike
04-03-2004 21:44:56
 Re: 4320 Wide Front End in reply to Wes, 04-03-2004 11:21:16
Call me I have the cure for your problem, been there and done it already numerous times 816-586-2841
RHA
04-03-2004 19:07:26
4520/4620 front end won't work. Go to the parts yard boys like Abilene Machine and get wide front from a 4430 (small hub) or a 4630 (large hub) with an adapter plate that will bolt to your 4320. Some also use wide front from 1370 Case with adapter. You should be able to sell your JD wide front and cover the cost of the replacement.
