JD1010
B.J.
04-03-2004 09:18:37
How do you remove the center on the axle of the rear wheel in order to get the wheel off? Looks like the center might require a spanner wrench of some kind in order to get it off. I am trying to get the wheel off to replace a seal. Anyone know? Thanks
jdemaris
04-03-2004 14:46:46
 Re: JD1010 in reply to B.J., 04-03-2004 09:18:37
I don't know if you've got an Ag or Industrial tractor, but . . . with a lot of the older Deeres from the 1960s, we had trouble with the wheel hubs coming loose on the axle splines. This included some 1010s, 2010s, and 440 and 540 log skidders. Came from the factory with a cast wheel hub pulled up tight on a splined axle with a cap and a bolt or two. Deere had so much trouble with them that they furnished repairs kits to glue them fast with Devcon epoxy. Later on, Deere started making the hubs and axles one piece units. So, in machines like I'm describing, you're supposed to remove the final drive and then pull the axle assembly to replace the seal. I don't know if this applies to your machine or not.
BJ
04-03-2004 18:34:57
 Re: Re: JD1010 in reply to jdemaris, 04-03-2004 14:46:46
Thanks for your reply. I have a 1010 RU tractor. Sounds like my hub is epoxied as I could not get the wheel to seperate from the hub. Do you have to do anything internal to remove the axle from the final drive? Maybe just have to remove the 4 bolts from the axle keeper? Thanks again. Appreciate your help!!!
Loren NC
04-04-2004 15:26:12
 Re: Re: Re: JD1010 in reply to BJ, 04-03-2004 18:34:57
Did you get the four bolts out of the axle clamp? I can get the nuts off of mine but there is no way the bolts will budge. I haven't gotten serious enough about the issue to work on it with heat yet, but I suspect that is what it will take to get four big bolts out of each side.
BJ
04-04-2004 15:42:24
 Re: Re: Re: Re: JD1010 in reply to Loren NC, 04-04-2004 15:26:12
Thanks for you reply. Haven't gotten to the bolts yet. A repair shop did the other side last fall and I plan to stop in ASAP and find out how he got it apart. When I do, maybe in a week or so, I will email you what I learned. He charged a lot to replace the seal on the other side so I want to do this myself if possible.
