'39 AR - couldn't get the flywheel bolt loose
Tracy Redd
04-02-2004 20:59:46
I was trying to get the flywheel off on 1939 U/S AR. I couldn't get the flywheel bolt loose at all. I have spent for hours trying get flywheel bolt loose. I broke 2 1/2" drive socket wrench and I bent 3/4" drive socket. My dad said that it would be best let him use torch to heat the bolt to cherry red and the bolt will loose.
Does anybody have any ideas about loosen frozen flywheel bolt.
Thanks
Tracy
John T
04-03-2004 07:07:11
 Re: '39 AR - couldn't get the flywheel bolt loose in reply to Tracy Redd, 04-02-2004 20:59:46
Tracy, I believe I would go with your dad on this one. When I have a nut I cant get off a bolt, I heat the NUT best I can all around around its circumference (NOT the bolt) and they seem to alwaysssss ss come off that way. You may wanna get new flywheel bolts and be sure you put her back on in time on the same splines and that the lil inner pin (if it has that) fits inside the oil slinger notch in that D shaped bearing and seal housing behind the flywheel. While in there, if shes leaking oil, you may wanna install a new cork seal located in that D shaped housing, I warm them in hot oil before installing. The flywheel has to be replaced to within 0.010 to 0.015 end play or so when you install it, we have one guy hold a sledge tight against the big outer nut over on the clutch drive as the guy on the flywheel side uses and oak board to get the flywheel back in tight.
Heat ought to do the trick let us know
Good luck n God Bless
John T
