35 B Block and Head????'ssss
TIM
04-02-2004 18:38:17
Have a few ?'s concerning my 35 B. Tractor has been sitting for 30+ yrs. I took the head off today, and the valves are rusted tight. I tapped on one and it broke off. The bottom part of the head from the drain hole upwards has been repaired at one time, but is not in a bad place and looks like it can be made to look decent with a little grinding. My ? is,is it worth trying to get the valves out or just look for a different head?
2nd ?, I took the main bearing caps loose from the crank, can a peron remove the block with the pistons in it? I am not sure where to pry on the block to get it to come loose. I have all the bolts out of the block, just not sure where to hit and pry 1st.
If you guys think I would be better off replacing these things, where are good sources? I am located in N.E. KS
Deere-Tom
04-03-2004 08:19:51
 Re: 35 B Block and Head????'ssss in reply to TIM, 04-02-2004 18:38:17
Tim, One of the best things you can do for your self is get a copy of a parts catalog(PC676-01FEB60) available from Deere.This will show you what things look like when apart and you will be prepaired with part numbers when talking to part or salvage people.Ok now to help with your questons,I would take the head to some one and have it checked out your local Deere dealer or auto parts should be able to help. As for the block, yes you can remove with pistons in it make sure you remove the bolts/studs that are though the frame into the bottom of the block.Then pry or jack the front of the block up and down until you can get a bar between main case and block. Also make sure you clean as much of crud and dirt that gets beween the block and frame it will amaze you how well this stuf will hold on. Good Luck
