water pump aftermarket, deere add on??
Bill R
04-02-2004 11:29:15
Ok, bear with me this is a sketchy description. I have com across a late john deere A that has a hole in the support that supports the end of the fanshaft, through this hole there is a shaft for a waterpump on the radiator side of course there is a pulley and on the back there is a waterpump with a greaseabe bearing. this is much higher than the lower water pipe hat it draws from so it has 45 degree elbows that are the same size the the lower water pipe, then as the bend and go up they slim down to 1-1.5 inch diameter to hook on the water pump. Does anyone have a tractor with this on, or has anyone ever seen one like it. I wasn't around when these tractors were working everyday and this is the first one I've seen. Sorry for the long description.
Bill R
A // B // GW // R Diesel
RayP(MI)
04-04-2004 17:15:57
 Re: water pump aftermarket, deere add on?? in reply to Bill R, 04-02-2004 11:29:15
We had a '47 B that would run hot when plowing or other heavy work. Remember my dad complaing about the great temperature variation when going into the wind, as opposed to plowing with the wind. One time when he had it into the dealer, it came back with a water pump. (Have no idea whether it was JD or aftermerket brand.) Other than that there was a hole cut in the frame under the generator, with a torch, for the water line, the assembly looked like it was a factory stock job. Ran off the now longer fan belt, so pulley was in line with fan/generator pulleys. Now have a '49 B, and am trying very hard to figure out how that thing was mounted on the old '47, cause the hose connection on the bottom of the radiator seems like it protudes too far back for such an installation. Wish I could look at that old B again! Anyway, it worked fine, cooling was never again a problem, and Dad got a kick out of asking the parts man for a water pump belt for a "47 B!
Bill R.
04-05-2004 19:54:15
 Re: Re: water pump aftermarket, deere add on?? in reply to RayP(MI), 04-04-2004 17:15:57
RayP, post back if you would like me to email you a photo of this setup.
Bill R
04-02-2004 23:23:58
Thanks guys, I have never seen one of these before, figured you guys could identify it for me.
Bill R
DP
04-02-2004 16:26:40
I've got one of those out in the shed. Was on my 49 G, and the best I remember, I believe it was known as a Johnson add on water pump.
mike
04-03-2004 21:50:56
 Re: Re: water pump aftermarket, deere add on?? in reply to DP, 04-02-2004 16:26:40
Just got in unstyled G it has one of these ad on water pumps kinda neat i think
Robert
04-02-2004 14:42:21
I had a pump similar to the one you're describing on my '45 A when I got it.
Once I finally got the tractor running, the pump leaked like a sieve, and, although I tried to replace the bearing and seals in the pump, after about 15 minutes of running time, it started leaking again. My solution was to go back to the original configuration (no water pump), and it was the best move I ever made---no leaks, and the tractor runs about 190 when it's working in this Texas heat.... I did have to buy a used lower water pipe to replace the pump set-up, though.
