Bearing UNDERSIZE ??
Gary U in NJ
04-02-2004 10:49:01
Ok, someone needs to explain the term "Undersize" as it pertains to Crankshaft and Connecting Rod bearings. This is how its referred to in the parts manual.
I assumed it was simply the increased bearing thickness to accomidate for crankshaft wear. I just spoke with the fellow building up and cutting my crankshaft, and he asked me what "undersize" meant.
Wouldn't it be "Oversize"
Thanks,
Gary
G-MAN
04-02-2004 10:59:37
 Re: Bearing UNDERSIZE ?? in reply to Gary U in NJ, 04-02-2004 10:49:01
No, bearings are available in undersizes. As the shaft wears or needs polished or ground, you're reducing the journal diamater, so the size will be "under" what the original diameter was. If you grind a crank .010", you need a "010" under" bearing. It takes a thicker bearing to accomodate the smaller shaft in a same-size bearing bore. Pistons and rings come in "oversize", because the bore increases with wear and honing or boring. There are/were also oversize valves available for a lot of engines, in order to tightly fit a worn valve guide, and oversize wrist pins to fit loose piston pin bores. That all goes back to the days when a lot more parts were reconditioned and rebuilt, rather than just replaced. Undersize bearings and oversize pistons and rings are still commonly used, but oversize pins and valves are rarely seen, at least when working on newer iron.
Gary U in NJ
04-02-2004 14:08:51
 Re: Re: Bearing UNDERSIZE ?? in reply to G-MAN, 04-02-2004 10:59:37
Great explaination - and its nice to know truth!
I put the brakes on the crankshaft work until I found out.
Thanks again, your input is truely appreciated
Gary
Bob
04-02-2004 10:56:45
When you grind the shaft smaller, the bore in the assembled bearing needs to be smaller, too. Hence the term UNDERSIZE.
When you bore a cylinder, the replacement piston needs to be BIGGER. Think OVERSIZE.
Gary U in NJ
04-02-2004 14:10:39
 Re: Re: Bearing UNDERSIZE ?? in reply to Bob, 04-02-2004 10:56:45
Bob,
Many thanks for the response. I guess its like the half full vs half empty glass thing!
Very appreciative,
Gary
