bigbadjohn88 , you ask... Quote: "The Y exhaust pipe has been rebuilt and poorly welded. When this tractor runs for about an hour an oil fuel mixture runs from the weld on the right side only. What do you think is most likely the problem?"...>>> Answ, probably either low compression on that side, a poor performing fuel injector, or a cold running engine, or a plugged air cleaner.. Quote: "Also I had the fuel pump and nozzles rebuilt. When installed fuel sprays from the back of the pump"...>>> Answ, What pump are you referring to? The transfer pump? Or one of the injector pumps?... In any case, fuel shouldn't come out of the rear or either one.. Quote: "If so where does this fuel go and where does the return fuel from the nozzles go?"...>>> Answ, There is no fuel return from the injectors.. What you are referring to is the bleed off lines.. All those do is drain off the very slight amount of fuel that leaks past the injector back into the intake manifold. [email protected]
