4010 dual rear wheels
Kevin
04-02-2004 10:27:39
I would like to install dual rear wheel hubs and rims on my 1961 4010. Deere shows 3 different axle lengths for this tractor. I have a row crop version of this tractor but is there any other way to tell if my axles are long enough to use the dual hubs or will they fit all three lengths?
thanks!
Kevin
04-03-2004 09:34:12
 Re: 4010 dual rear wheels in reply to Kevin, 04-02-2004 10:27:39
Buick&Deere, Mike and G-Man thank you for your responses. Any information and alternative ideas are greatly appreciated.
buickanddeere
04-03-2004 06:40:41
It maybe worth considering just getting a wider set of rims and radial tires. Sized right you can reduce compaction and gain traction with only 6psi tire pressure.
Mike Aylward
04-03-2004 06:21:27
Kevin, depending on the wheel spacing you want to use you should be able to use the hub duals with any length axle. If you have the wheels in the minimum tread setting there is room on the axle to install a dual wheel hub. A factory dual hub takes about 5 inches of axle length and an M&W hub takes 7. When you install either of these hubs be sure your main wheel is tight because you can't tighten them very easily with a dual wheel hub attached. If you are going to want your drive wheels spaced in a wider setting you will be limited to rim duals (clamp-on type). Hope this helps. Mike
G-MAN
04-02-2004 10:52:30
That's going to depend on what spacing you're on, and what spacing you want between the duals. If you want to go on 30-inch spacing, you're probably going to need a pretty long axle. There are also hub spacers available.
