1949 John Deere model A , play in sterring wheel
J B Adcock
04-02-2004 05:25:33
i have just finshed my tractor and have a round of play in my sterring wheel. this was not a problem when i started work on my tractor. i think i have done something wrong when putting the sterring rod back on. Can anybody tell me how to fix this problem? Thanks JBA
Dave K
04-02-2004 11:30:44
 Re: 1949 John Deere model A , play in sterring whe in reply to J B Adcock, 04-02-2004 05:25:33
Narrow front?? There is an adjustment on the sector gear to tighten up the play. Don't know what you did to loosen it but, if everything else is back together correctly, adjust the sector. When you adjust it with wheels straight you need to leave enough play so when you turn the wheels right or left they do not bind.
Dave
Chris
04-02-2004 06:35:41
Did you make sure to turn it in far enough? Make sure your bearings are all in place with the races.
