Ehaust Manifold and Marvel-Schebler Carb
Barry Rhoads
04-01-2004 19:54:40
Anyone,
I have a 60 Serial no. 6059426. It has the all fuel ehaust manifold. The tractor does not appear to have ever had the aux. tank. Does have a hole in the dash where fuel selector switch would have gone. The carb is a M-S with the following on the brass tag DLTX M 69 82L the patent no. is 2770254. I believe this is a carb for a 70 gas tractor. I anyone can verify I would greatly appreciate it.
Thanks,
Barry Rhoads
Duane Larson
04-01-2004 20:22:01
 Re: Ehaust Manifold and Marvel-Schebler Carb in reply to Barry Rhoads, 04-01-2004 19:54:40
Barry,
You are correct, the DLTX82 is for a gas 70. The other numbers are normally the manufacturing date of the carb, but I don't make any sense out of the number pattern other than the 82. The 69 could be the year, but there is usually a number stamp from 1-12 representing the month prior to the year stamp.
Your 60 AF (if that is indeed what it is) came with a DLTX84, while the gas burner used the 81. I suspect the 84 may be hard to find.
