JD 50 carb HELP!!
David
04-01-2004 19:51:14
I am rebuilding the carb on my JD50. I have pretty much got it back together except I am a bit confused about the float adjustment. The kit says 1/2" from the top of the bowl to the top of the float. Where on the float and where on the bowl do you measure this? This float has a round top. It actually goes up into the top of the bowl area a bit.
Would like to know where exactly where you measure to set this float.
Any other carb adjusting tips would be appreciated.
Thanks!
David
Duane Larson
04-01-2004 20:12:29
 Re: JD 50 carb HELP!! in reply to David, 04-01-2004 19:51:14
David,
Lay your carb upside down, with the threaded bowl neck pointing up. Lay a straight edge across the highest point of the float, and using a ruler measure the distance from the straight edge to the machined grove where the bowl gasket fits. That distance should be 3/4". If you choose to measure the fuel level in the bowl with a hose barb in the drain plug hole and clear tubing on the barb and held up along side the bowl, the fuel level will be very close to the top of the bowl (as opposed to single barrel carbs).
Other thoughts - the bowl nut gasket goes inside the bowl, not between the bowl nut and bowl (although I normally put one each place when rebuilding duplex carbs). Also, make sure the bottom of the bowl is flat - they seem to be warped sometimes. Open the idle needles 1 turn each, and after installing the metering adjusting screw (with new O-ring) in the center of the bowl nut, gently seat it and open it 2 1/2 turns.
Bolt it up, and there is a procedure for setting the idle needles which involves shorting out the left hand plug and maximizing rpm by adjusting the right hand idle needle, then vice-versa with the right hand plug shorted. If you need detailed instructions for that process, post back. I'm out of town for a couple days to a swap meet, but someone like Clooney or John T or ..... can provide that info.
David
04-02-2004 14:12:38
 Re: Re: JD 50 carb HELP!! in reply to Duane Larson, 04-01-2004 20:12:29
Thanks a million! This should get me going.
