Charles, try running it with the choke partially to almost fully back on & see if it runs & launches better.. If so, try opening the carb's load screw [the one closest to the center of the tractor] about 1/4 to 1/2 turn more & see if it launches better... If the choke helps but the farther open load screw doesn't suspect a fuel blockage or a plugged or plugging main nozzle.. ~To check for a good fuel flow to & THROUGH the carb just open the carbs bottom float bowl drain cock & make sure you have a pencil sized stream of fuel flowing for at least 30 seconds [if not you have a plugged strainer at the tank, or carb inlet, or a plugged tank outlet. ~If opening the carb's load screw a little more [maybe even up to a full turn more] doesn't help your launch you probably should pull the carb's load nozzle for a look at it's emulsion holes] ***************** Removing The Load Nozzle********************** ~ To do that just remove the carbs float bowl [be real careful removing the bottom bowl nut as the carb stem breaks easily & watch you don't lose the nozzle retaining spring],, then you will probably have to at least tap threads in the bottom of the nozzle.. DON'T drill it first, just find a tap that will fit the hole & use that..
~Try to find a standard size tap so you can use a long bolt or piece of all-thread rod that will fit the tapped hole.. Don't run the tap in any farther than about 1/4" on those DLTX carb's.. You don't want to tap in so far that you effect the bottom metering holes that are drilled in the side of the nozzle.. ~Once the load nozzle has threads tapped in it's bottom just use a long piece of all-thread threaded rod with a stack of washers with a nut on the bottom.. Screw the all-thread in the bottom of the load nozzle, then install the washers & nut & when the nut is tightened the nozzle will pull out .. DO NOT pry on the top of the nozzle to help it out as any damage there could severely effect carb metering. ~Once the nozzle is removed clean the air emulsion holes that are in the side of it.. [if some of the holes are plugged you have probably found your problem].. ~If the choke partially back on doesn't help any you might have a governor to carb rod adjustment problem.. To adjust that just remove the carb rod at the carb's top lever, then hold the carb wide open & hold the governor arm all the way towards open then adjust that linkage rod so it is 1/2 to 1 hole size short of entering the carb lever hole.. ~Your problem really doesn't sound like a valve problem especially if it isn't popping back through the carb or making funny noises out the exhaust when pulling a load.. ~If none of the above points you to your problem just post back or E-mail as there is more to check out but the above are the most common causes of your specific problem.. [email protected]
