Tye, a few things to consider... ~The front end strength is about the same but the square wide front is a little stronger... The 620 should have the square wide front, the 70 will probably have the round wide front.. A lot of the 70 gas or diesels did have the square wide installed at one time though if the wide front was added later.. ~Probably the biggest concern is the gear speeds.... Both the 70 gas & the 70 diesel will have a real fast 1st gear & fast reverse.. Not a big problem but can cause a problem in tight areas or rough ground.. The 620 or 720 will both have creeper 1st gears [unless the 720 has the 8mph 5th gear option].. ~The frame on the 720 will be plenty strong & 620 won't be too bad.. ~Both the 70 & 720 gas will use plenty of fuel while working as those things are gas guzzlers unless worked to their size.. The 620 will be much more fuel efficient when doing light work.. The 720D will be good on fuel, handle a loader well, & has decent gear speeds but it's heavy & big & parts are expensive.. ~The 20 series does have better hydraulics & would operate a loader & 3-point better.. ~My personal choice would the 620 for all around loader work & light to moderate estate of farm work.. Maybe the 720D if heavy field work was also required.. ~In any of the tractors considered I would highly recommend power steering as a 70-720 with a loader, & with manual steering will be a REAL MEAN steering machine.. [email protected]
