B drill Help!
Hunter
04-01-2004 09:32:19
Have a Van Brunt B drill and can't read the setting chart under the lid. I need to know where to set it to plant lespedeza @ 30 pounds per acre. THANKS!!!!!
Duane Larson
04-01-2004 12:19:05
 Re: B drill Help! in reply to Hunter , 04-01-2004 09:32:19
Hunter,
The Operator's Manual for the Van Brunt FB fertilizer-grain drill gives a setting of 12 for 24 lbs/acre and 16 for 33 lbs/acre of lespedeza. Those settings are for 6.00x16 tires on the drill. Correction factors are given for different tire sizes - let me know and I can provide those if needed.
Hunter
04-01-2004 13:33:12
 Re: Re: B drill Help! in reply to Duane Larson, 04-01-2004 12:19:05
Duane, thanks I think the tires on my drill are 15 in.
Duane Larson
04-01-2004 14:24:26
 Re: Re: Re: B drill Help! in reply to Hunter, 04-01-2004 13:33:12
Hunter,
Perhaps you should check for sure - the manual only lists correction factors for 16" tires, and I would imagine 15" would definitely require a correction.
