48 A JD Question
Eric
04-01-2004 09:10:41
Just aquired a 1948 A with a power block. I am new to deeres, the exhaust does not smoke, but there seems to be smoke coming out of the belt pulley area. What is this, any suggestions appreciated.
John T
04-01-2004 11:39:20
 Re: 48 A JD Question in reply to Eric, 04-01-2004 09:10:41
Eric, not knowing what care and what kind of oil (detergent or non detergent etc) its had most of its life puts you to some disadvantage. The fact its not blowing blue smoke out the stack is a positive indication at least, thats usually worn rings and/or valve guides. UNLESS you're for sure its had ONLY non detergent oil all its life, I would be tempted to change to a good multi grade detergent oil, add a couple quarts of Rislone, and give her a good long hard workout getting her up to 180 to 195 degrees or so and see what happens similar to what the good clooney man was talking about. I believe theres an oil slinger behind the area youre talking about and maybe theres some clogs/crud which a good clean and flush with detergent oil and Rislone might help clean.
Let us know, Good Luck n God Bless
John T
Clooney
04-01-2004 09:27:11
Eric, you say...
Quote: "there seems to be smoke coming out of the belt pulley area" ...>>> Answ, that usually means you have some combustion blow-by, probably due to leaking piston rings or bore wear..
~If you just bought that �A� try changing the engine oil, then working the tractor with a good heavy load for a few hours.. Maybe the rings are just stuck a little or there is some light rust on the cylinder walls..
~If after a good work-out the smoke still continues, then you will probably need to check the rings & cylinders, or just live with the smoke.. If the blow-by isn�t too bad it really won�t hurt too much..
[email protected]
