How can I find the coolant leak
Toby
01-24-2004 16:19:03
I have a 4240 with a 466 in it. Radiator was foaming after running a few minutes. Small air bubbles while running. I pulled the head and did not see much evidence of a head gasket leak that I could recognize What did I miss or where should I go from here.
Thanks Toby
Brokenwrench
01-24-2004 16:57:04
 Re: How can I find the coolant leak in reply to Toby, 01-24-2004 16:19:03
While you have the head off, take it to a reputable machine shop and have it magnafluxed. Also check your liner height(standout)to make sure you don't have a sunken liner.
david val
01-25-2004 00:20:02
 Re: Re: How can I find the coolant leak in reply to Brokenwrench, 01-24-2004 16:57:04
aeration (air entering the system) can also come from the water pump. it's a bit late now, but letting the engine run without a belt for a while can eliminate this possibility. while head is off use a stong light source and visually check for cracks in the cylinder walls (you can also clean head surface and check for cracks visually before the proffesional crack test).
david
