Deere model 146 loader
Indydirtfarmer
04-01-2004 03:30:27
I found a good deal on one, removed from a 2440 like mine. Everything is there, it's in exelent shape, and the price is right. Anyone have a 146? How sturdy is it? Is the "Quick-tach" mounting system easy to deal with? Right now, I have an "aftermarket" loader for the tractor, and I don't like it. (Makes it hard to get on and off the tractor) Let me hear the thoughts of some 146 owners. John
Dave in S MN
04-01-2004 11:11:21
 Re: Deere model 146 loader in reply to Indydirtfarmer, 04-01-2004 03:30:27
Hi-
The 146 is a very good loader. We use one at the dairy farm I work at mounted on a 2640. It works very well and we use the auxillary valve as mentioned before. We also have a 148 mounted on a 4030 at home. This has proven to be a good system over the years. has handled a lot of manure. they are a pain to take on and off though as mentioned. These are good loaders. Probably worth as much now in good condition as they were new.
-Dave R
lloyd
04-01-2004 10:00:34
We have a 145 JD loader on the 2240,I think its a great loader,lots of power,great lift it does as others have stated,everything from dung to ditch rock and does great !!
John 51
04-01-2004 08:44:01
Yes, I have one adapted to fit on a 2520. It's a good easy to use loader sized for tractors in the 40 to 60 hp range. I don't think it's built heavy enough for 3020s or bigger. Mine gets a lot of use from stones to manure. I have no problem with heavy hard pack steer manure. I would reccomend an independent valve to make it handier. AS far as taking it on and off, by far the easiest thing to do is run under a beam, take out 4 bolts on each side and pull it up with a come-along. The system Deere used is a pain.
I can get the specs from the manual when I get home if you want them.
Robert
04-01-2004 08:17:23
The 146 is very similar to the 148, just a little lighter. Mounts the same as a 148. Nice loaders, should give you easy access on and off. All the ones I have seen bolt onto the permantly mounted brackets in front of your steps with a few bolts, not to hard to take off should you want too. I am sure someone on here knows all the lifting cap. and such. Should work great for you!!!!! !!!
