Another question on rod and main bearings
Marty Z
03-31-2004 21:02:53
My rod journal is slightly out of round . Would I be better to make the rod caps slightly tighter during that one point of rotation, and let them wear in. Or should I make them free rolling through out the entire rotation. Right now I can feel some drag at one point .
Parade and show tractor only.
Thanks
Marty Z
Clooney
04-01-2004 04:02:20
 Re: Another question on rod and main bearings in reply to Marty Z, 03-31-2004 21:02:53
Marty, you MUST set the bearing clearance at the tightest point of rotation. There always has to a enough clearance to allow an oil layer to remain between the bearing & crank journal. If you try to "let them wear in" about all you will do is wear the babbit away or chance overheating a bearing..
[email protected]
