4010 LP tank pressure...
Rudy
03-31-2004 17:51:23
Oh great JD tractor gurus, I come to you yet again for advice.
My 4010 gas gauge(from the dash) has been on the blink and sporadically works, always thought it was the rat eaten wiring that I would fix someday. I have always used the pressure gauge on the tank itself for accurate readings. To make a long story short, my neighbor borrowed the 4010 to plow and it had at least 3/4 tank of LP. He plowed for less than a hour and the dash gauge read empty as well as the pressure gauge. He immediately brought it back to be filled, much to my suprise it took less than 10 minutes to fill (I know it is full because LP is coming out the top screw valve) but the pressure still shows 0. Does the pressure gauge really go bad? How does it work just by sitting in its recessed square on the tank?
Any ideas or comments would be greatly appreciated!
Mike
03-31-2004 18:46:27
 Re: 4010 LP tank pressure... in reply to Rudy, 03-31-2004 17:51:23
It has a float inside the tank just like one for a gasoline tank,but it's built for higher pressure and the float can rub a hole and fill with liquid and sink to the bottom,you'll have to run it out of fuel and BLEED OFF ALL PRESSURE!!!!! and remove the gauge and check for a hole AND one other thing that may have happened is there is a set of gears that the float arm works on can when well worn jump some teeth,which throws the needle out of time with the float.Either way you have to remove the gauge from the tank. Hope this helps Mike
scottAR
03-31-2004 18:43:31
I'm not saying you don't have a pressure gauge, I've just never seen one on a tractor. The gauge that my 4010 had was a percent liquid measurement. And yes they do go bad but most of the time they just stick. A magnet is all that makes the needle move. Any little bit if trash, rust, or spider webs can make it stick. (1) Using a brass punch and a medium ballpein hammer, hit the flat surface between the big screws and a lot of the time the gauge will start working. (2)If that doesn't work and the gauge is determined to be faulty, it can be replaced without having to empty the tank. Try to unscrew the small screws that hold the gauge on. If they twist off that is ok as about all you can get anymore is a glue on gauge. I think I used 3M Super Weatherstrip Adhesive on the last one I repaired.(3) If it still doesn't register correctly, the tank will have to be emptied and unscrew the big screws to remove the float assembly. This probably should be done by a licensed LP man.
Rudy
03-31-2004 20:29:13
 Re: Re: 4010 LP tank pressure... in reply to scottAR, 03-31-2004 18:43:31
Scott, you are correct. It is a percent liquid gauge. I did remove just the gauge and it has a lot of grime, dirt, etc. behind it and on the what I know know is a magnet. I'll clean both up real well and see if that fixes the problem. I noticed that I could shake the gauge to move the needle to 10 to 15 percent when it was removed but as soon as I got it close to the magnet it immediately went back to zero. So...either my float is stuck inside (because I just filled the tank) or this small gauge is faulty. Wonder if this small gauge is expensive or even available? Thanks for the advice.
scottAR
04-01-2004 18:23:31
 Re: Re: Re: 4010 LP tank pressure... in reply to Rudy, 03-31-2004 20:29:13
The last gauge I got was real cheap. I bought $390 of propane and he gave the gauge to me!
