48 G first reduction gearshaft endplay question
doug vose
03-31-2004 17:34:57
Ok, we are in the process of putting the ole G back together, and while installing the first reduction gear and cover, i noticed a lot of endplay. After installation of the cover, i tightened up the gearshaft castle nut as far as I dared. Upon installation of the gearshaft bearing cover, the endplay went away. My question is, is this normal/OK. Thank you in advance for your responses.
doug
mike maines
07-12-2004 15:51:02
 Re: 48 G first reduction gearshaft endplay questi in reply to doug vose, 03-31-2004 17:34:57
KILL YOURSELF, and tighten my nuts.
Clooney
03-31-2004 17:47:06
Doug, yes that is normal.. That outer input shaft bearing is what controls the end play in that shaft..
[email protected]
John D
03-31-2004 17:43:43
Doug when I went to replace the first gear reduction cover on my G the gear was very loose and wabbled after instalation of cover it all tightened up. I figure I had a bearing out or something, but it runs great so I would say its ok. John
