820 found in bush
Russ
03-31-2004 14:45:17
Hello
Last Sunday I was out dirtbiking and passed by a old abandoned farmyard. I happened to catch something green & yellow in the corner of my eye. I got a closer look at it. Sitting next to a 65 Massey, I had found a green Dash 820 serial number 8200901. It has a Aftermarket cab. It is in nice condition. The tractor is complete and has excellent tin. the motor was loose & it had fair rubber. The only problems I noticed was the clutch is siezed up, most likely from sitting outside, and the tachometer glass was smashed. I looked on my RM map to find out who owned the land it was on. I called the guy and he said he used it until 1993 when he quit farming. He said it's not for sale right now because it's tied up with the estate right now. he will be callng me back once it's settled. What do you guys think it's worth? If I buy it & restore it should I remove the aftermarket cab? What do you guys think about these tractors?
Thanks,
Russ
mike a
04-01-2004 13:12:10
 Re: 820 found in bush in reply to Russ , 03-31-2004 14:45:17
probably the worst way to find out who owns property is to dirt bike on it without permission
Whats an RM map
03-31-2004 16:00:40
I always wondered how to find the owner of a piece of land. How do you do it? By the way, I am in Texas.
Loren NC
04-01-2004 05:24:39
 Re: Re: 820 found in bush in reply to Whats an RM map, 03-31-2004 16:00:40
You can usually find owners right from your own computer. An easy way to start is just to go to your favorite search screen and enter the name of your state and county. Most counties now have their own web site. Once you find that, look for a link to GIS Maps and find the area that interests you. Or you can choose the link to tax appraisals. Likely you will find a search field there that will allow you to search on a road or street name. After you get that close, you can start picking and choosing until you find the correct property. Most likely there will be an option to map the property you select, which will help you identify whether you have chosen the correct one. Might take you a while to pick up on how your particular county site works, but it can be well worth the effort. If nothing else, it pays to see what the county has to say about your property. I found that I was being taxed for a barn I tore down a couple of years ago.
Mike in Louisiana
03-31-2004 17:14:54
All you have to do is go to the court house in the county the property is located, and go to the assessors office and they will help you (MOST OF THE TIME). Try to have some of the names of the people close to the property and or address.
Mike
Russ
03-31-2004 17:06:29
Hello,
In Canada, we have RM's (Rural Municipality). an RM map is a big grid map showing every quarter section of land and the name of the owner. They also show bodies of water, landmarks (such as old countryside schoolyards, etc) I guess they are alomost split up like counties for you americans.
Jake
04-01-2004 07:30:39
 Re: Re: Re: 820 found in bush in reply to Russ, 03-31-2004 17:06:29
Hey Russ where in Canada are you? Western?
jhill
03-31-2004 20:35:36
In the U.S. you can buy a plat book for most areas that gives the name and acreage of properties 10 acres or larger. The ones I have are printed by a company called Rockford Publishers. You can also find out at the Registrar of Deeds office in your county.
