G or GM?
Kevin Kowallic
03-31-2004 11:33:22
I have a 1947 G s/n 24475. It has the pan seat, battery is in front of the engine, and it has round axles. I was looking for battery hold down clamp for it, and was told it is a GM. How do I find the history my tractor? Thanks.
Kevin K
04-01-2004 06:21:12
 Re: G or GM? in reply to Kevin Kowallic, 03-31-2004 11:33:22
Thanks, for the help. I will take a closer look at the tag, when I get it out this weekend.
DP
03-31-2004 21:30:44
I believe the GM model was changed back to G at SN #23000, and The battery box under the seat at SN #26000. There was a gap in numbers just before #23000, but yours would be a Model G
John D
03-31-2004 17:30:11
I have ser #24450 and on the tag it says G not GM. Last GM was ser #22112. In 1947 3 G's were made GM, G with pan seat and G with bench seat.
The Rodent
03-31-2004 17:12:17
I have resently bought a pullin' tractor it was a 1947, sounds just like yours. And mine was a GM.
G-MAN
03-31-2004 16:02:37
I don't know the serial number break between the last "GM" and first styled "G" right off the top of my head - somebody else will, but there is no difference in the tractors. The first styled "G"s (which did finally show up in '47 if I remember correctly, although the decision to go back to "G" had been made in '46) had the pan seat and front-mounted battery just like the "GM". I think that if it's a "GM" it should say so on the serial number tag. If it's a "G", it should say that. J.R. Hobbs' Styled Letter Series book is an excellent source of info on those tractors. It lists serial number breaks, major improvements, matched working equipment, production numbers, etc.
