3020 engine swap 4 to 6
wags
03-31-2004 06:03:15
Have a 3020 diesel, will the 404 bolt onto the rearend/tranny or are they different?
JD 4020 3020
03-31-2004 13:03:31
 Re: 3020 engine swap 4 to 6 in reply to wags, 03-31-2004 06:03:15
Yes they will work with some parts change. I know of a are farmer who had a 4010 with a bad rear end, and a 3020 with a bad motor. He had a local mechanic take the 2 good halves and make a nice one of a kind side console 4010. He said it was real easy to do and the only issue was with lining up hydraulic systems because of the different styles of control used. In your case, the 4020 motor is bigger than the origional 3020, or even the 4010, so I would be slightly concerned about how well that tranny will hold up with the 4020s extra power, especially if you will be pulling it hard.
WTW
03-31-2004 06:43:39
The 404 engine will bolt right to the 3020 rear end. Flywheel from the 3020 diesel will bolt to the 404. Know of a few of these that have been done. Frame rails and sheet metal will have to be altered. You can use 4020 frame rails and alter sheet metal accordingly. The 3020 hood height and radiator is lower than a 4020 but engine will fit under hood same as the 4 cylinder does. The 404 is the same dimension as the 270 only two cylinder longer. DW
