Carb?
B JDfarmer
03-31-2004 05:37:43
I have a late model b jd. it had no carb on it when we bought it. we bought a carb for it the other day. it is one for the earlier all fuel b's. is their anything wrong with using it on the gas only later model b?
John T
03-31-2004 06:02:37
 Re: Carb? in reply to B JDfarmer, 03-31-2004 05:37:43
JD Farmer, Im no carb or fuel expert, but in my opinion, an All Fuel Carb (so long as still for the B) ought to work on a Gas Only tractor, as its will run with Gas ORRRRR Distillate/Drip Fuel (i.e. an All Fuel Carb). The All Fuel Tractors were intended, of course, to start on Gasoline and then once up to temperature (to keep fuel vaporized and used the hot manifold) to be able to use the heavier Distillate or Drip Fuels. A Gas Only manifold isnt as hot in the area needed to keep the fuel in a vapor state (as needed for Distillate), but since youre running Gas, it shouldnt be a problem. The chart I looked up shows for a Model B the carbs were:
SN 1,000 - 95999 DLTX 10 All Fuel SN 96,001 - 200,999 DLTX 34 All Fuel SN 201,000 and up DLTX 67 Gasoloine SN 210,000 and up DLTX 73 All Fuel
Good Luck n God Bless ya
John T
