JD 4430 Trans Trouble
smurph72
03-30-2004 20:57:19
Help please..... .My cousin's 4430 quit shifting while mowing yesterday. It would travel forward at a creep (1st gear) or reverse at relative fast speed. When I put it in Park and let out the clutch, the engine died.
I couldn't feel the gear selector detents/shift points (for lack of a better description). The gear shift would travel from front to back (1-8) positions with no change in gear, speed, or engine sound. The only change was forward to reverse.
Now it won't start. I'm assuming the safety cutout to keep from starting in gear is keeping it from cranking. It felt to me like the linkage was separated or broken, but I had no idea where to start looking.
Thanks for any info.
dcm
david val
03-31-2004 05:10:26
 Re: JD 4430 Trans Trouble in reply to smurph72, 03-30-2004 20:57:19
assuming from your description that this is a powershift, there are three cables going out of the shift console, one for park, one for for-neu-rev, and one for the 8 gears.
put the tractor on LEVEL ground and chalk it for safety. follow the cables under the right side of the cab/platform. with the engine OFF!! have someone shift the lever in all gears. in f-n-r the short lever on the valve housing should folow lever left-right movement in neutral. when shifting gears the long arm should follow lever for-aft movement. if it doesn't, the cable may be torn, a pin is out or something is wrong with the shift mechanism.
david
smurph72
03-31-2004 09:25:13
 Re: Re: JD 4430 Trans Trouble in reply to david val, 03-31-2004 05:10:26
Thanks for the info. I'll check it tomorrow and post back. BTW it's a powershift.
dcm
Brokenwrench
03-31-2004 03:34:12
The linkage runs from the quadrant to the right side of the trans. Without knowing which trans you have(synchro,quad,powershift) any further diagnosis would be a quess.
