3 point hitch problem on a JD 2030
Phil Lowery
03-30-2004 11:43:11
I am still having trouble with my 2030 3 point hitch system. The rate of drop valve is 1/2 to 1 turn open, and the load-depth control lever is set to "D". When I move the control lever approximately 4 inches the the system raises to its max height. The lever still has 4 to 6 inches of travel left. The 3 point hitch arms feel like they are moving in spurts instead of a normal hydraulic movement. I have already changed all the filters, the hydraulic pump in front of the tractor, and the valves under the rockshaft cover. Is there some type of adjustments that I can make? Is there a certain way the valves must be aligned? What about the actuating rods? Can they be adjusted?
david val
03-31-2004 05:29:29
 Re: 3 point hitch problem on a JD 2030 in reply to Phil Lowery, 03-30-2004 11:43:11
something is probably installed incorrectly in the rockshft mecahnism. you need to remove the rockshaft and check all pars indide for good condition end correctness of assembly. it's best to use a tech manual or an experienced jd mechanic. after intallation you need to do the step by step adjustment.
david
