Can't get my 1950 MT to run
Darryl
03-30-2004 09:43:36
I'm not a mechanic, but I'm not mechanically inept. One thing that I don't have a specific concept of, though, is how a carburetor works. My trouble-shooting skills are also somewhat limited.
That said, after experiencing some problems with my 1950 MT, I ordered a rebuild kit for the carburetor. I followed the directions as well as I could, never having been that intimate with a carburetor before. There didn't seem to be much to it. With high hopes, I reinstalled the carburetor and tried to get the tractor to run. This tractor used to always start after 2 or 3 turns before the problem surfaced (it died and then would only sputter before refusing to start again). Well, I cranked it quite a while (not continuously) before it started. It ran very rough and then finally smoothed out.
At this point, I enjoyed the sweet sound of the two cylinders, but all was not well. Whenever I advanced the throttle, it began to cough and spit -- it acted like it was flooded. After a short while, it evened out. I tried adjusting the needle on the main jet (it wasn't hard to get the idle adjustment set), but to no avail. It just wouldn't work right.
After it ran for quite awhile (it was warmed up to operating temperature) and after I had tried everything I could think of, I shut it down. I haven't been able to get it started again. It coughed and fired a couple times this morning, but it wouldn't start and run.
I've taken the carb back off, checked the float level -- it seems fine (according the directions I have -- and the gas level in the bowl was not overflowing). There continues to be a regular drip of gas through the drain screen which is located under the choke. There's gas getting into this part of the carb which is then dripping through the screen. It will do this if I just leave the gas turned on (rather than shut off before the sediment bowl).
I'm frustrated and am unable to figure out what to do. I think it acts like it's flooded -- the spark plugs get wet. Yes, I did put in new spark plugs. There is spark at the plugs.
I want to get the tractor running. It's got work to do. So, I appreciate any help that you can provide. Thanks!
Darryl
Dave K
03-30-2004 11:34:43
 Re: Can't get my 1950 MT to run in reply to Darryl, 03-30-2004 09:43:36
It sounds like you are running too lean a mixture. This is adjusted (hopefully) by the load and idle needle valves. Do the presets on them per the instructions you have (I don't know them offhand for the MT) Now, the idle adjustment will effect the load and vs/vs so you really have to work them together and it is sometimes just a little patience and SMALL adjustments each time. If that is not the problem then you need to be certain you are getting a full flow of fuel from the tank to the carb. Open the carb drain valve (if it has one) and open the fuel shut off and watch for at least a 30 second good sized stream of fuel. (Do outside!!) If you get none here or it does not have a drain cock, loosen the fuel line where it connects to the carb and check for good fuel flow. If good here and not at the drain on the carb, your float is probably sticking or the inlet screen in the carb is clogged. If it will not start even when you choke it it may either be flooded (remove plugs see if wet) or you could have a leak around the intake manifold gaskets. These are just a few suggestions to get you started, there are folks on here who will probably give you more detailed instructions. There is also a possibility of clogged passages in the carb body itself. However, this simply sounds to me like getting the mixture settings right.
Dave
Clooney
03-30-2004 11:34:28
Darryl, that slight drip from the carb air intake bottom drain is somewhat normal right after shut down but if it continues for more than a short while it means you have carb needle & seat problem or a float that doesn�t float very well..
I don�t know how far you went into that TSX carb but if you didn�t pull the load jet [above the load adjusting needle] & clean the passage above that you will probably have to do that.. That load jet does come out with difficultly & in some cases has to be heated or drilled out..
~You also need to clean the [very small] idle air orifices & idle holes in the top casting above the gasket & clear up in the top the inside of the upper air horn� It wouldn�t hurt to also make sure the economizer passages are clean & not partially blocked..
~Be sure the float actually floats & isn�t contacting the carb bowl side or has a hole in it.
~I have a rather nice cut-a-way view of a TSX carb showing the idle holes & economizer passages & load jet area & even though it�s for a 40, the general parts & operation are about the same so I will try to send that to you later tonight..
~On that float level � You might want to remove the carbs bottom drain valve & install a 1/8� pipe hose fitting, then install a clear plastic hose on that fitting, then wire that hose up next to the float bowl with the top of the hose left open & well above the top of the carb.. Then turn the fuel on & watch that hose. That will show the actual fuel level in the carb bowl & allow you to see if the float bowl fuel level is raising above the set level.. At least that way you will know if you have a fuel level problem�.
[email protected]
