Clooney (on the SDL)
Henry J
03-30-2004 05:18:32
Clooney
I read thru all the posts on the other board about the CDL. I always feel like my fly is open when I drive down the interstate with a tractor on the trailer.
Guess, I havn't tried hard enough, but really don't know the minimum requirements for tie downs. Mine has always been "over" tied down I think and I have never been stopped.
If you have the basic requirements to memory, I would appreciate if you give us a shout on it.
Clooney
03-30-2004 10:10:11
 Re: Clooney (on the SDL) in reply to Henry J, 03-30-2004 05:18:32
Henry, I haven't had to re-take a full CDL test in quite a few years. In Michigan the renewal CDL test is considerably easier than the original & the DOT rules seem to change about every year so I can't give you current information..
~About all I can say is go to your state's DOT current rules & check the requirements for your weight class & towed/towing equipment [you can do that on the internet]..
~You are doing the correct thing by over killing the tie down.. Usually 4 corners of a farm tractor will get you by but if you use over center chain binders be sure to lash the handles from popping open� Use tie down DOT quality chains [not log or tow chains], & tie in as high as you can� I got stopped a few years ago for tying to the draw bar but I think my speed at the time might have been what initially got their attention then the stopping officer gave me a pretty good going over & even questioned the viewing angle of my trailer tail lights [I have those lights well forward & protected on each side for protection against breakage from the rear]..
~For a single tractor I usually use 4 corner chains & an additional fore/aft safety strap on both ends of the draw bar [the strap isn�t required by DOT, that�s for me as I don�t want that tractor in the truck with me if something catastrophic should happen] ... A single rear chain looped through a draw bar clevis usually isn�t legal unless it is boomed off as a separate chain on both sides, at least that�s what my local DOT guy told me]�
~Your best thing is to [look] legal & not do anything to draw attention to your rig..
~Some states are much stricter than others.. Here in Michigan if it will follow you down the hi-way & has brake lights the law pretty well leaves you alone.. I sure can�t say that about some of the other states but maybe an out-of-state trailer plate doesn�t help there either..
[email protected]
