301-a timing specs
DJ Huffman
03-30-2004 05:04:06
I am ranch manager of a nonprofit Mounted Girl Scout Troop 2571 located in Cedar Hill MO and we have a 301-A that is out of time. We need the timing specs to get this tractor running again.
Any help would be greatly appreciated.
DON
03-31-2004 08:46:34
 Re: 301-a timing specs in reply to DJ Huffman, 03-30-2004 05:04:06
LOOK AT THE CRANK PULLEY FROM THE RIGHT SIDE, FIND THE TDC MARK, JUST ABOVE IT THERE IS ANOTHER MARK "SPARK" SET THE TIMING WITH THIS MARK AND THE POINTER AT WIDE OPEN THROTTLE. DON
jdemaris
03-30-2004 05:40:01
It is a gas or diesel, and are you trying to set the static timing or the advance?
DJ Huffman
03-30-2004 11:04:56
 Re: Re: 301-a timing specs in reply to jdemaris, 03-30-2004 05:40:01
It is a 3 cyl gas engine, and I would like both specs.
Thanks
DON
03-31-2004 08:50:42
 Re: Re: Re: 301-a timing specs in reply to DJ Huffman, 03-30-2004 11:04:56
THE DIESEL IS THE SAME ONLY THE SPARK LINE SAYS "INJ" . LINE UP THE TIMING MARKS ON THE PUMP AND FRONT PULLEY AND COVER POINTER DO THIS WITH ENGINE OFF. DON
DJ Huffman
03-31-2004 08:58:44
 Re: Re: Re: Re: 301-a timing specs in reply to DON, 03-31-2004 08:50:42
What I'm looking for is the gap setting for the points on a 3 cyl gas engine and whatever other advise someone can give. We have no manual on tractor so any help is welcome. DJ
