Clooney Im Lost
Firefighter
03-30-2004 04:49:38
A friend bought a mid 40s B and it has a dltx53 on it and I rebuilt it and reinstalled and cant get it to idle without surging is this carb just to big or what? when you put it in low gear and throttle up you cant hardly pull it down with the brakes also at high idle it still kind surges but pulls fine Im thinking it should have a DLTX34 Any thoughts? Thanks again for the valuable Info Firefighter
Clooney
03-30-2004 09:39:33
 Re: Clooney Im Lost in reply to Firefighter, 03-30-2004 04:49:38
Firefighter, that DLTX 53 is off an "A" with a considerably larger engine so the correct metering is difficult at best..
~I'm sure that carb size is part of your problem but I have gotten those larger carbs to operate close to correct on the "B"..
~One thing you have to keep in mind & that is the fact that a 53 will have to be real crisp to operate correctly on that "B".. That means absolutely no wear on the ends of the throttle plate, no wear on the throttle shaft bushings, & all the metering holes free of dirt & rust..
~Another thing you might want to do is draw file the manifold end of the carb rear flange so it is perfectly flat & seals to the manifold gasket correctly..
~Then make sure the idle stop screw spring is there, not bent, & adjusted correctly..
~Here�s something else to check for: Does the idle & load needles have full control? � OR, do you not see much engine change when you turn them? � If not much control you might still have an internal carb problem..
[email protected]
