Mark, how are you checking for a spark? � Both spark plugs on a cylinder head must be touching the pony or tractor chassis to get a spark from either. [the coils need both plug bases on a coil grounded for either to produce a spark].. ~Next make sure ALL 4 plug wires are plugged into the coils around the rear of the distributor.. On the push to seat coils those plug wires pull out of the coil easily if pulled or tugged on. ~If all OK per above then open each set of points & place a piece of paper or match book cover between the points [that is to keep the coils from burning out while testing the system].. ~Next turn the pony ignition on & test for around 6 volts of power at the pony distributor power wire stud. If none found, then look for a broken wire between the starter push button & pony distributor.. If no 6 volt test light or voltmeter handy just remove the cardboard from between one set of points at a time & use a screw driver to short the points together [points already open] or pry the points open [points already closed],, then watch the dash ammeter while doing so & you should see it deflect to the negative side with the points closed & return to 0 with points open.. If one plug wire per cylinder head is also pulled & hooked to a spark plug laying on the chassis or pony you should also see a spark there when the points are opened from a closed state or a screw driver is wiggled between open points.. ~If no spark in the above test give the coils a good sniff test.. If they smell burnt you were probably playing around with the pony for too long with the pony ignition left on & now the pony coils are burnt out [it doesn�t take very long]. ~Next test.. Place a 6 volt test light [you will probably have to make one] on each pony distributor condenser wire binding screw & the pony distributor�s base plate [basically a good clean ground] then crank the pony motor.. If the points are functioning correctly & the condensers aren�t grounded out the light should flash on & off with the pony cranking.. If test light never comes on with the points held open suspect a burnt out coil or no power to the distributor.. If the light always stays on suspect oxidized points [so clean or replace the points].. If the light does flash off & on while cranking, & the plug wires are indeed hooked up to the coils, & the spark plugs are both grounded to the pony, YOU SHOULD BE GETTING A SPARK.. You can use a voltmeter in the above tests but a cheap digital meter might not work as the meter response time is too slow.. ~If still no spark in all the above tests suspect burnt out pony coils.. If you have ever left the pony ignition switch on for long with the pony NOT RUNNING then really suspect burnt out pony coils.. ~If you suspect burnt out pony coils you can remove the coil primary wires[black wires] from the condensers & power stud & measure the resistance of the primary in each coil [should be somewhere around 2 ohms give or take a little on a cool coil] If the coil primaries are open, the coils are definitely bad.. In some cases correct measured coil resistance still won�t show a bad coil so keep that in mind.. ~You could also measure the coils secondary resistance [between the plug wire towers [probably over 8K ohms but less than infinity but those pony coil�s secondary very seldom go bad.. ~Another place to look if you have an intermittent spark is to be sure the pony distributor has a good ground to the pony engine [make sure the 4 hold down screws are tight] & make sure the distributor cam isn�t loose or wobbling around on the shaft� ~Your statement.. Quote: �it would either pull good or start good, but not both at the same settings��>>> Says you might have a carb problem.. On most ponies I have worked on when the starting & pulling power are split it usually means the pony carb has a blockage in the main jet [usually due to a crumbling carb float] or the pony rubber fuel feed hose is de-laminating inside & causing a fuel restriction [sometimes just opening or closing the fuel fill door will make the difference if the hose is the problem].. ~If you do show a spark in the above tests start with a brand new [not old cleaned] set of Champion J-8C spark plugs & then if it starts try playing with the choke to see if you can effect the pony power & runability.. You might try opening the carb load screw [on top of the carb] to see if that helps & be sure the pony air cleaner isn�t plugged with dirt & crud [or try running it with the pony air cleaner removed].. ~If it does start pointing to the carb instead of the ignition you might try a new float in that pony carb & while the top of the carb is off try cleaning the float bowl & load jet inlet holes down inside the float bowl. ~Most pony power problems I run into are caused by floating junk in the carb float bowl, either caused by a deteriorating float or deteriorating inside of the rubber fuel hose. ~I�m sure you have some questions so either post back or E-Mail me directly.. [email protected]
