3010 shifter problems
frank
03-29-2004 18:35:19
In one of the earlier postings an individual indicated that the shifer detents may get worn and sloppy and need to be replaced. The person making the posting indicated that the detents are spring loaded and one should be careful when the plug that holds them is removed.
How does one safely remove these and are they had to compress when one gets ready to reassemble them?
Brokenwrench
03-30-2004 04:05:54
 Re: 3010 shifter problems in reply to frank, 03-29-2004 18:35:19
The detent springs are only 10#-15# pressure at most,unless someone has replaced them.Much more pressure than that and they get hard to shift. Just hold the plug tight when removing it.
Frank
03-30-2004 05:37:27
 Re: Re: 3010 shifter problems in reply to Brokenwrench, 03-30-2004 04:05:54
Brokenwrench:
Thanks for the information.
frank
