HELP - - Standard or Hydro Static Transmission
Tracy, Marion,
03-29-2004 14:26:24
I'm considering buying a new JD 990 with a 430 front-end loader, and I can't decide to go with a standard transmission or hydrostatic transmission. I like the forward and reverse control of the hydro static, but I'm more concerned with reliability. How reliable are hydrostatic transmissions vs. standard transmissions? I'm going to be doing the normal chores with 6 acres -- fence work, digging, mowing, and roadwork. Any advice would be appreciated!
JDKIA
03-31-2004 10:42:20
 Re: HELP - - Standard or Hydro Static Transmission in reply to Tracy, Marion, TX, 03-29-2004 14:26:24
Hydro trans have less power and take more fuel than collarshift trans, the old Farmalls were a very good example of this, the hydro had 20 less horse power than the collarshift.
Mike M
03-30-2004 09:23:55
Hydro's are great! The best for loader work but I'm not totaly sold on them they zap some power.
I still can't get use to having the engine run at full throttle all the time,this is where the hydro's are made to run and don't work very good at less speed.
Clooney
03-29-2004 16:49:46
Tracy, I agree with Jacksun & Frank, I have a 755 hydro & it has been trouble free..
For mowing, loader work, yard work, post hole digging, light back blade work it can't be beat..
I tried some heavy duty disking & wasn't pleased though as the trans hydro temperature went way up do the the constant slippage.. Even in low range it felt like I was working it too hard.. For everything else it is great..
[email protected]
jacksun
03-29-2004 14:51:40
tracy as long as you dont use it to plow it is great. the benefits out weigh the cost you dont have a clutch the only thing you need to do is change the fluid and filter. i have two one is nine years old and never had a problem with either one. so iwould go with the hydrostat with the loader its a breeze no changing gears from foward to reverse and with three range selections the speed is variable.
F-I-T
03-29-2004 14:57:55
 Re: Re: HELP - - Standard or Hydro Static Transmis in reply to jacksun, 03-29-2004 14:51:40
I second the notion of jacksun. I have an 855 which is hydrostatic, and the transmission has been trouble free since new (1990).
I would have expected more adjustments with a conventional transmission (which I also have).
You'll find it great for loader work.
Frank
