Help!-Need Torque Specs for 47 JD M
Shawn B.
03-29-2004 14:05:57
Can't find my service manual and I need torque specs for my rods, head bolts on my JD model M so that I can button the old girl back up. Any help would be appreciated. Thanks,
Shawn
Clooney
03-29-2004 16:26:57
 Re: Help!-Need Torque Specs for 47 JD M in reply to Shawn B., 03-29-2004 14:05:57
Shawn, the ..
Cyl head torque is: 105 ft lbs, start at the center & work you way out in a crisscross pattern.. Work your way up in 20 ft lb increments then use 10 ft lb increments for the last few passes..
Rod nut torque is: 55-60 ft lbs.
[email protected]
flywheel and ....
03-29-2004 15:10:51
How much torque to put on the flywheel bolts and also, is there a torquing pattern for the head?
Clooney
03-29-2004 16:30:13
 Re: Re: Help!-Need Torque Specs for 47 JD M in reply to flywheel and ...., 03-29-2004 15:10:51
Shawn, I don't have the flywheel bolt torque for the M but if you don't get an answer tonight or tomorrow I will look up the one for the Deere 40,, it's probably the same...
[email protected]
