G troubles
JDBert
03-29-2004 13:59:39
I just bought a 51' "G" with some problems. First the carb has a broken ear thats been welded back together (even goes into the carb alittle). has anyone ever fixed one of these, nothing againest Roberts but he wants $500 to fix and rebuild it. 2nd the brass clutch engagement is broke (I dont even have it) are these the same in a 70, or "A" as I have both for parts, or are they a breed all their own? 3rd I'm missing the generator bracket, are these the same as a "A" or 70?
Thanks in advance
JDBert
03-30-2004 06:57:10
 Re: G troubles in reply to JDBert, 03-29-2004 13:59:39
I miss understood Robert, he gets $65- $125 to repair and $140 to rebuild. Thats not bad considering the excellent work he does.
Gman
03-29-2004 15:28:12
JDBert here's a guy that might be able to help you with the parts you need and a fine fellow met him at a swap meet in Iowa His name is Ron Stephens email is [email protected] later Gman
Gman
03-29-2004 15:12:40
Bert the carb can be repaired,but will take someone pretty experienced to repair,DLTX-51's are a popular carb for pullers but you should be able to find one,also the other items go to a swap meet or an salvage yard. There's a big swap meet in Portland ,Ind May the 15th you'll find all the G parts you need might be pricy but they are there.I have blocks and pistons and a few odds and ends parts. Gman
