Frustrated 3020
Randy
03-29-2004 11:41:43
I am completely frustrated with my 3020 gas. New points, wires, plugs, carb. kit. Drained tank cleaned all filters. Still hesitant and missing when under power or reved up fast. Tried playing with load adjustment and float. Any and all suggestions welcome!!!!! !!
thanks
Wolfie
03-31-2004 06:28:26
 Re: Frustrated 3020 in reply to Randy, 03-29-2004 11:41:43
Same thing happened to me I had a miss and put in a set of new champion plugs. Still missed started to replace wires thinking they are old. Replaced cap and rotor still missed replaced the coil still missed. Then I said what the heck just maybe it is still the plugs bought a real cheep set and it ran like a clock. I will never ever buy champion plugs again. Try the plugs again.
Wolfie
mike
03-30-2004 07:19:12
When my Allis Chalmers WD acts this way it has been the condensor. Even if the condensor is new, it may be a "bad" one.
DON
03-29-2004 12:47:58
RANDY , JUST BECAUSE YOU HAVE NEW PLUGS DONT MEAN THEY CANT BE BAD. NOW REMOVE THE DIST CAP AND TURN THE ROTOR AND LET LOOSE WILL IT RETURN. OR EVEN MOVE ? IF NOT THE SPEED ADVANCE MECHANISM IS STUCK. YOU WILL HAVE TO READJUST THE TIMING . ALSO DOES IT HAVE THE POTMETAL CARB ON IT ? IF SO THE ACCELERATOR DIAPGRAM IS PROBABLY BAD. ALL IT TAKES IS FOR THE ENGINE TO BACKFIRE AND BLOW A HOLE IN IT. REMOVE THE REAR COVER AND IT IS IN IT. NEXT THING COULD BE BURNED AND LEAKING INTAKE VALVES. A COMPRESSION TEST SHOULD SHOW THAT. HOPE THIS HELPS. ONE MORE THING IS THE LOAD SCREW ADJUSTED OUT FAR ENOUGH?? DON
Randy
03-29-2004 12:52:34
 Re: Re: Frustrated 3020 in reply to DON, 03-29-2004 12:47:58
If the rotar does not turn, how do you get the speed advance unstuck?
thanks
Roger/IA
03-29-2004 16:39:30
 Re: Re: Re: Frustrated 3020 in reply to Randy, 03-29-2004 12:52:34
To get the advance mechanism freed up, remove the plate the points mount to. There will be two weight devices and two springs. You can check for weight movement with a screwdriver moving the weight at the end away from it's pivot. There is usually a wick device under the rotor to supply oil to the advance weight mechanism shaft so it can pivot on the distributor shaft. Put a few drops of engine oil on it. Make sure it pivots freely. The weight movement causes the rotor shaft to move on the distributor shaft.
Does sound like a fuel problem, however.
Good luck,
Roger
Randy
03-29-2004 12:55:53
Also, it is a Zenith carb. I have tried moving the load adjustment in almost every position. The book says around 1 1/2 turns, but it does not seem to want to run there, it seems to run best around 2 to 2 1/2 turns, but still falters.
thanks
JMS/MN
03-29-2004 11:46:45
Air cleaner? My 3020 diesel has the oil bath type, imagine yours does too. Might need a good flushing out- often overlooked. Takes a lot of air to make power. Also- how about the coil?
Dave in S MN
03-29-2004 12:41:38
 Re: Re: Frustrated 3020 in reply to JMS/MN, 03-29-2004 11:46:45
Sorry, that was supposed to be a reply to the first post. My apologies.
-Dave R
Dave in S MN
03-29-2004 12:40:01
Hello-
I don't know how much this'll help, but you said any and all suggestions welcome, so here goes:
You you said underpowered when revved up. We just had the fuel tank off of our 4230 this weekend and found there was a line that was being pinched between the tank and the frame. You might want to check your fuel lines and make sure none of this kind of thing is occurring.
Also you mentioned all of the new parts you have. Remember that just because its new doesn't mean it HAS to work. There's a lot of junk that's sold out there. I'm not saying you bought a bunch of junk, but i'm saying it's always a possibility.
Just my thoughts.
Take care.
-Dave R
Chances R
03-30-2004 03:57:10
 Re: Re: Re: Frustrated 3020 in reply to Dave in S MN, 03-29-2004 12:40:01
Is your 4230 a GAS model?
