420 W two stage clutch
Nat
03-29-2004 08:02:10
I found a 420 W that I want to buy. The seller says it has live power, but mashing the clutch doesn't stop the PTO. I held my foot on the pto shaft and it didn't stop with him holding the clutch down. Can it be stuck, as he has not used the pto in years,or does it need to be adjusted, or am I missing something? any help appreciated, Nat
Henry J
03-29-2004 11:10:53
 Re: 420 W two stage clutch in reply to Nat, 03-29-2004 08:02:10
Nat
On your first post you did not say if you could disengage the pto or not.
A thing I would try is to have the tractor shut down. See if and when you can turn the pto shaft with your hand in both positions of the pto engagement lever and the trans in gear. That should tell you by the direction of the lever as described earlier if the pto is live or not.
Just off hand it sounds like the one I have/had. The last person that put the tractor together winged the clutch assembly and the pto clutch just wasn't disengaging - ever.
If the clutch is set up right you should be able to feel the free travel (around 1 inch) and then feel about half way down when the pto clutch is hit and by pushing the pedal all the way down it disengages (just like the ford). If you are not feeling the place where the second stage of the clutch is engaged and the pto clutch is then supposedly disengaged by pushing the pedal all the way down you can do all the stuck clutch tricks you want, it won't unstick if it is not disengaged.
My clutch was so botched up that when I took it apart, you could still see the numbers on the pto clutch disk. It had never worked from day one - whenever that was.
I bought a used 11 inch disk at the time for $50 that should be in there when the grandkids probably junk the tractor because it sounds like it is just hitting on two cylinders lol.
I made a tool like described in the service manual but didn't have a new 11 inch disk to set the clutch up as described. My first setting (to the gook spec) was not right on. On the second go around I added .050 to the distance specified in the book for the fork adjustment and it came out right on.
Good Luck if you buy it, but watch out for a curve ball if you don't really know the person you are buying the tractor from or maybe he just picked it up and don't know the tractor either.
chuckw
03-29-2004 10:33:25
have been through some of these...as suggestion would be to couple the bushog, get it going, maybe roll it off to prevent starter damage. While hogging in tough grass, hit the clutch and see if it will break loose. It may be only frozen. If not it will need to be seperated and probably replaced properly adjusted. The tech manual has a pattern for adjustment guage. If I were buying I would reduce offer by about $500.
SteveA
03-29-2004 09:56:58
Nat, the 420 with live pto operates with the foot clutch just like the Ford you described, halfway for transmission, full down for pto. To make sure it has the live option, it has to have a 5 speed transmission, and the engagement lever will move towards the transmission shifter to engage. If it moves away from shifter to engage it is not live pto. Steve
JDKIA
03-29-2004 08:43:59
Which clutch did you step on the main clutch? if it has live power then the PTO will have it's own clutch
Wayne in Tn.
03-29-2004 09:46:16
 Re: Re: 420 W two stage clutch in reply to JDKIA, 03-29-2004 08:43:59
There will only be one clutch pedal to use the PTO. With the PTO in gear, letting up halfway on the clutch pedal should start the PTO running, Letting the rest of the way up should start the tractor moving.
If the tractor really has (live) PTO, there will be two clutch discs and a special pressure plate inside the bell housing.
This is a somewhat complicated system to make repairs on, as the pressure plate must be adjusted perfectly, within thousands of an inch to work correct.
From the way you describe the tractor, it may need complete overhaul of the clutch system, this can be pretty expensive on those (live) Dubuques.
I have been through it all, and honestly, I had rather have a Dubuque without (live) They are lots cheaper to repair and will work longer.
On my (non-live) tractors, I just buy what is called an override clutch that attaches to the PTO shaft. Then the bushog or whatever equipment, just attaches to the override clutch.
JDKIA
03-30-2004 18:05:02
 Re: Re: Re: 420 W two stage clutch in reply to Wayne in Tn., 03-29-2004 09:46:16
"There will only be one clutch pedal to use the PTO. With the PTO in gear, letting up halfway on the clutch pedal should start the PTO running, " then is isn't live... Live PTO reffers to PTO that is completely seppearte from the foot clutch the Allis tractorshad "live" pto to but if you stepped on the clutch it killed the pto, this is not "live"
nat
03-29-2004 09:38:35
I had him step on the main clutch. I wasn't aware that there was another. Can you explain where or what other kind of clutch it would have. I only have experience with a ford 2 stage clutch, and on them you push pedal partway down to stop tractor, and then all the way to stop the PTO. I had an Oliver 550 that had a seperate lever to engage/disengage the PTO, and I am familier with the kind that stops both tractor and the PTO when you depress the clutch pedal. Is the another clutch on a 420 W that I don't know about? I know there is a lever beside the transmission shifter that you can put the PTO in gear with, but I would think that with a bushog on the tractor you would need to disengage a clutch before putting the PTO in gear. Any Help? Thanks , Nat
JDKIA
03-30-2004 18:09:15
 Re: Re: Re: 420 W two stage clutch in reply to nat, 03-29-2004 09:38:35
"I had him step on the main clutch. I wasn't aware that there was another. Can you explain where or what other kind of clutch it would have. " if it has a live pto then it will have a seperate clutch located on the tractor somewhere, Based on the responses I don't think that the 420 had a "live" pto
Wayne in Tn.
03-29-2004 09:51:14
Nat, you are correct, that is the only clutch pedal. I have had them to not dis-engage like you said. You have to kill the engine in order to put the pto in gear. This is not supposed to be this way. This means something is wrong with the pressure plate or the clutch discs. The last time I checked, the two discs and pressure plate was around $500 not counting throw-out bearing and whatever else may be wrong.
Nat
03-29-2004 17:06:54
 Re: Re: Re: Re: 420 W two stage clutch in reply to Wayne in Tn., 03-29-2004 09:51:14
I realy appreciate the help. The PTO lever engages by pulling toward the shifter tower and it is a 5 speed. This tractor has a JD 45 loader, It does't appear to have been used much, no breaks or welds, straight metal, and the pto shaft doesn't appear to have ever been used. It is a one owner tractor. The Gentleman who owns it bought it, and a 420 T new and has used them on a small NC beef operation. Says the PTO hasn't been used in so long he can't remember.
JDG
03-29-2004 20:51:57
 Re: Re: Re: Re: Re: 420 W two stage clutch in reply to Nat, 03-29-2004 17:06:54
Nat Try hooking PTO to something,clutches may be stuck from no use. I had a 420T that acted the same way. This fix it for me, probably luckey once.
SteveA
03-29-2004 17:55:36
Nat, would you email me your location? thanks, Steve
Ray
03-29-2004 17:52:30
It's normal for the pto to drag or keep running
on a 420 or 430.The replacement disc are a little
wider and made of different material than the
originals and will drag untill worn in good.
The easiest way to tell if it has live pto is
to look below the right bottom corner of the
serial tag.Tractors with live pto have a 3/4
threaded stud sticking out of the bellhousing,
tractors with non-live pto have just a threaded
hole.It's hard to tell on some just feeling
the clutch as usually only the bottom inch of
clutch travel operates the second or pto clutch.
