2030 point problem
Phil Lowery
03-29-2004 06:59:10
Help! I have a problem with the three point hitch control system. I can move the lever a few inches and the system will raise to its highest position. To get it to go down, I have to move the valve under the seat. Any ideas?
david val
03-29-2004 14:45:48
 Re: 2030 point problem in reply to Phil Lowery, 03-29-2004 06:59:10
did it work ok before?.
the valve under the seat is the rate of drop valve. in normal use it should be opened some, if its closed copmletely the lift arms will not drop. there is a load-depth control lever on the right side of the rockshaft. this lever should be positioned at 'd' for all 'not in the ground' implments and attachments. in this situation (valve opened and lever at 'd'), the lift armes should 'follow' lift lever all the way up and down and stop when the lever is stopped. if this is not the case the lift system needs adjusment or repair.
david
david
