730D winter operating temperature
Bo in Maryland
01-24-2004 12:36:33
..... what temperature do you fellows like to run at in winter conditions?....my operator's manual doesn't give guidance....right now I'm barely getting up to 140 degrees pushing light snow in 20-32 degree weather..... should I block off the grill screens to run hotter?..... opinions/comments/experiances most welcome.
Good luck to all!
Bo
Bo in Maryland
01-24-2004 15:45:46
 Re: 730D winter operating temperature in reply to Bo in Maryland, 01-24-2004 12:36:33
.....thanks 720 Deere and Don..... you guys confirmed my hunch that at 140 degrees I'm running way to cold.....I'm gonna block her off tomorrow morning..... the weatherman predicts a real duzy of a storm coming in tomorrow afternoon and night.....
thanks guys,
Bo
720Deere
01-24-2004 13:31:58
Bo,
I run have to block off a good 3/4 of the radiator on my 720D in the winter. Even at that I am lucky to reach 180 if I work it. Those diesels suck in a tremendous volume of very cold air and it takes alot to keep the temp up. Blocking the grill screens doesn't help much because there are still so many places that the air can still draw through. Block as much of the radiator as you can with cardboard and that should help.
DON
01-24-2004 13:19:35
IT IS ALWAYS BEST TO RUN UP TO OPERATING TEMP. OF 180 DEGREES. THAT OLe 730 WOULD HAVE TO WORK PRETTY HARD TO GET THAT WARM IN YOUR TEMPS.AS THERE IS A LOT OF IRON THERE TO DIASAPATE THE HEAT, COVER HER UP AND RUN AS HOT AS YOU CAN WITHOUT BOILING THE WATER. DON
