830 transmission oil
farmerherron
01-24-2004 12:21:46
I have a 2-cyl 830 SE. Just drained the transmision oil and what came out appeared to be hydraulic oil consistency. Do these tractors use hydraulic oil instead of gear lube so the pump can circulate the oil better? Does it take hydrualic oil or gear lube? Thanks for the help.
buickanddeere
01-24-2004 13:35:02
 Re: 830 transmission oil in reply to farmerherron, 01-24-2004 12:21:46
Your operator's manual which you purchased at a reasonable price from Deere 1-800-5227448. Among many other vital points of info states which oil in which reseviour. Incluiding places one won't think of finding and draining/filling hidden in out of the way places. SAE90 GL1 for winter winter usage.
farmerherron
01-24-2004 18:25:02
 Re: Re: 830 transmission oil in reply to buickanddeere , 01-24-2004 13:35:02
Thanks for the help. I just haven't received my operators manual, it didn't arrive with my service and parts manuals, not sure why. They must of had to order it. Thanks again for the help.
Gpower
01-25-2004 06:32:40
 Re: Re: Re: 830 transmission oil in reply to farmerherron, 01-24-2004 18:25:02
Hey Farmer, I will try to give you information you requested, as I know sometimes you get answers not needed. The R, 80-820-830 has a transmission oil pump that lubes the transmission and enclosed gears. Your 830 will hold 3 1/4 gallons in the transmission,diff. area. It recommmends a 90 weight oil. I have started using the 80/90w as it flows easier and has lubed really well for several years. That is my personal preference and I am sure that someone will say thats wrong on here. The transmission pump really does not develop a lot of pressure in the system, but it does have a lot of flow to it. Thats the reason I run the 80/90 so that the old pump doesnt work as hard pumping that thicker oil. You may wish to check you pump out and you can do that by removing a plug on the bottom of the triangular plate which is right back/behind the steering arm on the bottom side of the tractor. It is a small square plug, remove it and with the tractor running you should get a steady stream of oil flow, then you know the pump is good and working. Just put a bucket under there and watch it a few seconds. You cannot use a guage as it will not register. Hope this helps
Gpower
farmerherron
01-29-2004 17:38:33
 Re: Re: Re: Re: 830 transmission oil in reply to Gpower, 01-25-2004 06:32:40
Thanks for the help Gpower. Great info.
