6O Power Steering- What fluid should I use?
R-man
03-28-2004 18:57:15
I drained the fluid out of the power steering on my 60. What should I fill it with? Somewhere I heard that it required something special.
Clooney
03-29-2004 05:21:47
 Re: 6O Power Steering- What fluid should I use? in reply to R-man, 03-28-2004 18:57:15
R-man, this question just came up a few days ago [see link]...
Soldier Tom
03-29-2004 05:00:55
The JD power steering fluid is what we're supposed to use I reckon. Now a while back we had a LONG string about the good and bad of JD PSfluid vs the rest, and as opinions varried pretty far, my service book said to put the JD Stuff in, so I did, not wanting to void the remaining 50 year factory warranty. :)
~Walk in peace~
Soldier Tom
Stuart
03-28-2004 19:38:13
It is a must that you use the OEM powersteering oil from John Deere. I have a 60 that I tried ATF in and then Hy tran and it runs the coolest and turns the easiest with JD ps fluid. It isnt cheap, I think 3.50 a quart. Using automatic transmission fluid is not a good idea because it has friction enhancers in it which is the opposite of what you want in an lubricant in that situation. Some dealers dont carry it and they would tell me what viscocity of oil it was, so I could not go out and by Shell brand equvilant or other brand. Also if the oil looks milky,crappy or has water in it you will want to fill it back up to the correct level, remove the hydraulic hose off the pedstal end and put it into a can, then run the tractor and turn the wheel until about a quart is in the can, essentially you are flushing the system. do this a couple of times to get the system good and clean. I hope this helps, post back if you have any problems and Good luck.
