1960 440 icd loader more help please???
scott
03-28-2004 17:53:29
Thanks again for the reply's
So here is another one:
The pistons were locked in very tight.
Came down to a post I read here!!!!!
I put lamp oil in the top of the cylinder with a small rag. With a jack under the piston with a piece of wood, we got it to move about . 010 at a time, both were stuck. It took all day. wow what a job. But I got them out without damage ... cylinder need a hone, rod caps look good as do the mains.
...., HOWEVER....
The crank still will not turn.
I figure the clutch is stuck to the fly wheel.
Fingers will disengage but its not coming free.
Anything I can try before I pull the motor forward a little and check it out?
Took the starter of and I can see a little bit in there.
Boy its been a big job....I hope someone can give me more helpful hints
Scott
Mike
03-29-2004 18:44:26
 Re: 1960 440 icd loader more help please??? in reply to scott, 03-28-2004 17:53:29
Even if the clutch is stuck to the flywheel with the trans out of gear it should turn anyway,So either the hyd. pump and or the trans is locked up,I would unhook the pump first,if it still won't turn remove the trans shifter cover and take a look.Mike
