74 model 4230 work lamps
matt
03-28-2004 01:43:12
I orderd a rubber gromet or bezel which holds the lamp in the rear work lamps on the roof from my jd dealer when it came it was too large to push onto my lamp holder it is a hobbs and part number R42689 on jd parts there are also R30182 and R54047 which one will i need ? any help will be apreciatrd
Adam
03-28-2004 17:27:14
 Re: 74 model 4230 work lamps in reply to matt, 03-28-2004 01:43:12
R54047 is no longer available. It is the bezel that has the side shield as part of it to block the light. I guess you can only try the other one. Good luck.
